cigarette lighter
Old Oct 1, 2003 | 07:30 PM
speedy_g's Avatar
Default cigarette lighter
My lighter quit working so now my radar detector does not work, it keeps blowing fuses. The stock is 25A and I am up to 50A just to see if it blows. Is there a ground I should look for, or a connection I need to clean?
Old Oct 1, 2003 | 09:03 PM
NightHawk's Avatar
Default Re: cigarette lighter
Whoa! Putting in higher amperage fuses is NOT a good idea. If fuses are blowing is it more than likely due to a short in the wiring or the accesory that you are powering. Keep puting in higher amp fuses and you'll melt your wiring
Disconnect your rader detector, and see if it still blows fuses, then check the socket and the wiring and see if you can find what's making it do that.
When did this start happening? Did you change anything or do any work on the area? Also wires being pinched together enough can cause them to short - you could check for that, too.
Good luck
Old Oct 1, 2003 | 09:07 PM
speedy_g's Avatar
It just started doing this yesterday. I only put higher amp fuses in to see if it would blow them and it did. It blows the fuses as soon as I hook up the radar. I have torn apart the radar and everything checks out okay. I didn't know if someone had this problem or not. If not I will look into it but not until my day off, whenever that is.
Old Oct 2, 2003 | 07:19 PM
Danny2tek's Avatar
stupid question.....have you tried using the cigarette lighter? if it still blows you have a problem in the wiring to the socket, if it doesn't blow,..but it does with the radar detector problem is the radar
Old Oct 3, 2003 | 08:25 AM
speedy_g's Avatar
Yes I havetried this to. I keep blowing the fuse with any type of accessory attached to that circuit almost insantly.
Old Oct 6, 2003 | 03:28 PM
whitez71's Avatar
Sounds like something with the lighter socket. Check and make sure there is nothing in it like a little screw or piece of foil.
Old Oct 6, 2003 | 06:42 PM
speedy_g's Avatar
It was all clean, I figured it out though, bad ballast resisitor. Gotta get a new one.
