Power window problem
I used my meter on both sides of the plug that attaches to the motor and both show 11mv when the up and down are pushed?
I plugged the motor back in, used a test light and again, Power with Up and Down, yet the motor only turns in the up position? The regulator is not in a bind either.
And yes, I returned the first motor (thinking it was bad) and the second does the same thing?
Also, doesn’t matter if you use the driver’s side switch or pass side...
--VIP!
--VIP1
