Stock speaker replacement
Now.....if you bypass the stock wiring and amp, and run speaker wires from your new HU to any old speakers you install, it might work out for you.
Changing the head unit has no effect on the speaker configuration. It doesn't matter whether you have the factory HU or you've installed an aftermarket one... as long as you're using the Monsoon amp, the speaker configuration won't change.
I called Kee Audio and talked to Ian he promised to call me back but hasnt even bothered. Im sitting here with money in my wallet and its burning me! I wanted a setup from him with a double din bezel but couldnt get a hold of him so I decided to go with the jvc 5.4inch sceen and got a jl stealthbox for cheap. wonder if a cdt 10 sub will go in there ok. Also bought a jl 500/1. also still need components and wanted to see what Ian would recommend and give me prices. but I guess I might as well match the 4 channel amp with a jl 300/4 since I got the 500/1. So what do you guys recommend as far as components? should I just uprade my 4 stock speakers? or should I get a set? If I get a set will I need different amp other than a 300/4? Give me some choses! I got a 97 camaro ss coupe. THANKS
