Alpine iDA-X100 Problems
Old Feb 17, 2009 | 01:23 AM
CaribooLou's Avatar
Default Alpine iDA-X100 Problems
I've got a weird problem with my head unit. When I open the door, it does not turn off. I tried my harness from my old alpine head unit and the one that came with this one just to make sure it wasn't a wiring fluke. I'm fairly certain the BCM is still in good condition because when I open the door the amp kicks off and the windows wont move.
Anyone have this problem?
Thanks
Old Feb 17, 2009 | 09:09 PM
Blackfly's Avatar
Sounds like you have an accessory wire crossed. Double check your connections are connected to the right wire on the harness. Just a guess.
Old Feb 18, 2009 | 03:29 PM
CaribooLou's Avatar
Double checked everything, when I first put it in i used the old alpine harness from my last head unit because it fit perfectly. The old head unit worked properly, this one doesn't turn off with either the old or the new harness.
