How to remove monsoon head unit?? Monsoon button-light question?
I'm planning on replacing my headunit with either an aftermarket head unit or a like new(or new) factory radio.
I pulled the radio out the other day to see what all connections were going to the back of the head unit since I had never taken one out of a camaro before, and on the large black wire closest to the driver side I couldn't see a way to disconnect it from the actual head unit. Please help!!! Is this the antenna or something??? Does this hook into an aftermarket head unit??
Also, I have some lights out in the head unit.....station preset 1 and 4 are out, along with the auto tone and eq *****. Is there any way to change out these bulbs???
Any help is greatly appreciated!!!! Thanks!!!
Should be the antenna wire, when I got my car it had already had the original swapped but when I changed it out to my Clarion and all I had to do was plug it right back into it. You should just be able to pull them apart.
Copy & Paste Moderator
The thick black cable should be the antenna. Its stiff, but will pull out.
Here is how Midnight F-117A replaced the bulbs in his Monsoon headunit with LEDs:
https://ls1tech.com/forums/showthrea...ht=monsoon+led
Here is another write-up:
http://xse.com/leres/ss/leds.html
