no power to compressor
What are the pressures on the system with it off? If there is pressure in the lines you can try jumping across the low pressure switch connector. If the compressor kicks on and the system runs fine, then the low pressure switch is bad.
its a wiring or electrical issue, not the compressor.
Last edited by WhiteBird00; Feb 25, 2009 at 01:56 PM. Reason: merge consecutive posts
Did you try tracing backwards in the circuit? Whats the next thing in line before the compressor? Check both sides of it to see if there is power coming to it, but not out. If it doesn't have power coming to it, then move to the next thing before that.
the motor has been out twice but we never disconnected any part of the ac system.
