HID headlight help
Old Mar 10, 2009 | 03:49 PM
92builtbird's Avatar
Originally Posted by VIP1
Yes. There will be some cutting and custom fabrication involved. If you are not comfortable doing this, there are people out there that perform retrofits. I don't know of any personally though.
Ok. Can you reccomend a good kit. IIRC 4200K is the most beneficial and produces the most usable light, but I want to step up to 6000K, because I like a hint of blue.
Therefore, I would need 2 bi-xenon projectors, wires, 2 HID Ballasts, and a little fab work.
Old Mar 10, 2009 | 03:52 PM
Nova5's Avatar
Hidplanet has those. head there, pick the HID link and then OEM. this will get you to the sales area of their site that has projector packages.
Old Mar 10, 2009 | 03:54 PM
From what I can see, those kits are 4100K, and one of them is discontinued.
Old Mar 10, 2009 | 06:35 PM
VIP1's Avatar
Copy & Paste Moderator
You took Nova5's suggestion too literal. Read around on HID Planet's Forums to find out what works best for your situation and buy the necessary components from a member on there or on ebay or Retrofit Source (avoid "replica" projectors, they aren't as good as the real thing -- replica clear lenses on the other hand usually are good). They have a sales section on there just like here.
Before you buy anything or spend any money. Read. Read. Read. Learn all you can. Read through the various threads on retrofits. Make sure you know what you are getting into. To possibly make things easier, see if there is already an aftermarket housing available for the Equinox that already has projectors. Typially the projectors are low quality halogen projectors. Sometimes you can fairly easily remove that low quality halogen projector and replace it with a good HID projector. Unfortunately I didn't see any such headlights for the Equinox on ebay. Alternatively, you can get a set of stock replacement headlights from ebay and do the retrofit into that set so that you can still drive your car while you take your time with the retrofit.
Old Mar 10, 2009 | 07:58 PM
Very good information. Thanks for your help. I will be looking into this alot more, that's for sure
I appretiate both of your guys' help. If I have anymore questions during the process, I will be letting you know.
Old Mar 10, 2009 | 10:47 PM
VIP1's Avatar
Good Luck.
Old Jul 11, 2009 | 04:43 AM
clairezeng's Avatar
Many guys don't know what bulb type will fit there car ,I think this site is very useful to help you find the right bulb for your car if you want to aftermarket a hid kits .
http://www.sylvania.com/ConsumerProd...lacementGuide/
enjoy the lights
Old Jul 11, 2009 | 04:44 AM
clairezeng's Avatar
The only you need to know is the car brand ,year made and modle ...
Old Jul 11, 2009 | 09:41 PM
VIP1's Avatar
That link is in the Lighting FAQ too.
