Rear Defroster problems
Old Oct 18, 2003 | 07:38 PM
Tudds's Avatar
Default Rear Defroster problems
I searched but found nothing...
last night I was driving home and it was freezing so I kept putting the defroster on...
now it doesn't work... I thought after a day it would work again(happened once before)
Where is the fuse for it? or what can i check? any input would be great
Old Oct 19, 2003 | 07:31 AM
hondakiller's Avatar
Default Re: Rear Defroster problems
its on the same breaker as the power seats are. my defroster used to mess up and trip the breaker after it had been on for like 30 seconds but it just kinda fixed itself? i dunno?
Old Oct 19, 2003 | 08:09 AM
Tudds's Avatar
So where is the breaker? How do i change it?
Old Oct 19, 2003 | 02:07 PM
mattsls1's Avatar
i got my windows tinted like a month ago and now only a couple of the defroster lines work. It looks like the lines either burned through the tint or its bubbling by the defroster lines. do any of u know what goin on. its pissing me off. yesterday i backed out of the driveway and almost hit my moms car. thanks a lot
Old Oct 19, 2003 | 05:17 PM
Tudds's Avatar
get your own thread pal
Old Oct 20, 2003 | 08:01 PM
its in the fuse panel by the drivers door, not sure which one it is but theyre marked so you should be able to find it .
Old Oct 22, 2003 | 01:50 PM
felton316's Avatar
The breakers they used for the defroster are a piece of crap. Its suppose to be a 30 amp breaker but they'll trip way before that! i yanked mine out and replaced it with a 30 amp fuse. I have never had a problem since. The defrost breaker is located in the fuse box by the driver's door. I believe the breaker was silver in color, but its been a long time since I've seen it.
Old Oct 22, 2003 | 01:56 PM
Tudds's Avatar
thanks a lot, I work at an autoparts store... I didn't know breaker was the same thing as a fuse
Old Oct 23, 2003 | 08:09 PM
wrencher's Avatar
wrencher
The switches also go bad.
Had a few that would keep drawing excessive amperage & had to replace the grid.
Thats right the rear hatch glass.
Old Nov 25, 2003 | 12:38 PM
pjb's Avatar
pjb
ditto what felton316 said. replace the breaker with a fuse - problem solved. Never tried a new breaker (differnt manufacture might help)
