Bose and Monsoon working together?
Now, I understand how both systems work. The Bose amp takes its on/off signal off the H/U from a single wire, and it runs the 2 bass speakers in the rear seat area (which I think are the same for all systems). The Monsoon amp takes both the + and - output wires from the H/U and sends them both to the base and rear mids.
So what I want to do is take the rear seat bass speakers away from the Monsoon amp and run them off the Bose amp, just like in the Camaro, and let the Monsoon amp run everything else like normal. Then I can use both amp outputs from the H/U.
Now my question is, does this sound like a good theory? Anyone tried this or something similar? Will the H/U even put out enough power to both amps for decent sound, or am I just spinning my wheels? It's a Sony CDX-GT4200.
Any input is helpful. I only ask this because I already have the Bose amp, and no reason to spend more money if I can help it. I have no problem wiring stuff up myself. Thanks!
The Monsoon "system" is really just an amp and specific speakers added to an ordinary Delco head unit - the same as in your grandfather's Oldsmobile.
The amp takes speaker level input and boosts it for the low impedance speakers.The Bose system consists of a system-specific head unit that outputs high-impedance, low-level signal (basically a headphone signal) to individual amps attached to each speaker.
There are adapters that will allow you to connect a Bose head unit to an aftermarket system but mixing Bose and non-Bose in a single system isn't advisable and may not even be possible.
I know the front 2 door speakers in the Bose system have individual amps, but I'm not talking about those. I'm talking about the rear bass speakers only, and those are run by the big Bose amp. http://shbox.com/1/bose_wiring.jpg
I am talking about taking bass away from the Monsoon amp and giving it to Bose. The H/U should be able to run both, since they have different signal outputs from the H/U.
I am pretty sure if I wire it right, it is possible. The only doubt I have is if the H/U can put out enough power for both amps for this to be doable.
Seriously. Get better speakers, as you can afford them, and use your HU's speaker outs until you can afford a real amp.
For the 6x9's that you bought, did you just run RCA cable from the H/U straight to the speakers? Or through an amp? Where did you put them, in the hatch area where the rear mids/tweeters sit?
