Harness for stock monsoon amp connector
Is there a wiring harness I can plug into the stock monsoon amp harness to run a different amp, instead of having to cut and splice the factory harness? Kind of like what is available for HU swaps.
I tried searching but the search is broken again.
You could do it with the right connector, but if you are going to use a bigger amp,
why not use thicker wire?
I thought about doing this once but decided i didn`t want to spend any more money on audio equipment.
IIRC it is a 32 pin connector, possibly pn# 702001 or 702002
Look into these connectors more before spending money, because I`m not positive on the pn`s.
Not necessarily a bigger amp, but I want to delete the monsoon amp and run my speakers from my HU directly, with a small amp for the sail panel subs. My pioneer is 4 ohm, speakers are 4 ohm coax, sail panel subs are 4 ohm, but the monsoon amp is 2 ohm with the front component so the front sounds and the audio in general lacking a little. 50W per channel is enough for me really, I just want the full range to the speakers and proper impedance matching for the best power transfer.
You will need a male and a female connector then.
What i was going to do was, get the male and female connectors and wire the
front tweeters and hatch speakers straight back to the stock amp and
by-pass the front drivers and sails to another amp.
taking this back to the top... Anyone know where to get a male connector to hook up to the stock monsoon amp connector so I don't have to chop up the original harness to remove the stock amp and just run straight from the HU? Or does such a thing not exist?
