Amp
Old Mar 18, 2009 | 07:14 PM
Choppers's Avatar
Default Amp
Hey there guys. right now i have a 2 channel amp running 2 subs. i sold my 2 subs and am going to go with 1 sub. can i still use this amp and will it put out twice as much power now to just one sub. by the way i have the california profile AP1200
Here is the link to the amp i have: http://www.crutchfield.com/p_489AP12...00.html?tp=115
here is the link to the sub i am ordering: http://cgi.ebay.com/KICKER-CVX10-CAR...3A1%7C294%3A50
Will this all match up good?
Old Mar 18, 2009 | 11:00 PM
99Bluz28's Avatar
No, you want a DVC 2ohm sub, not a DVC 4ohm sub.
Old Mar 18, 2009 | 11:01 PM
fspeedster's Avatar
Nope, that sub is a 4 ohm DUAL voice coil, if your going with a single sub, you need a 4 ohm SINGLE voice coil or a 2 ohm dual voice coil sub. That way you can bridge your amp to it's required 4 ohm load.
Old Mar 18, 2009 | 11:02 PM
Choppers's Avatar
why a 2ohm? i am not very audio inclined. so will my amp work just fine with it? or do i need to find a 2ohm dual voixe one as well?
Old Mar 18, 2009 | 11:06 PM
samson_420's Avatar
If you have a 2 Ohm dual voice coil sub you can run it down into 4 Ohms.
So you will be using the most of your amp. Or just get a single 4 Ohm voice coil sub.
Old Mar 18, 2009 | 11:17 PM
Choppers's Avatar
yea i want the dual voice coil sub. so your saying look at the dual 2 ohm. ok now how will i wire it into that amp. put the + and the - where one of the 2 go now or do i just use the center plug ins?
so will this sub be the correct one: http://cgi.ebay.com/ws/eBayISAPI.dll...Category=18805
Old Mar 18, 2009 | 11:26 PM
fspeedster's Avatar
Yes that sub will work, try this http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
