*1800watt System install**PICS*
Is that the bass **** as supplied with the Cadence amp from Kee Audio?
If it is, did you replace the original lighter with the know, or did you make a hole there? I have a different console in my T/A, so I'm not familiar with what was there.
Yup, its the cadence bass ****. I pulled the lighter out, then used my dremel to make two slots in the bezel to slide the amp motherboard thinggy into. Then I glued it in place. =] If you want I have lots of pics of how I did it, gimmie your email and ill send you them!
