Mounting amp HELP!
Old Mar 21, 2009 | 09:22 PM
Pharm0r's Avatar
Default Mounting amp HELP!
Hey tomorrow I'm bolting down my amp right above the gas tank....how do yall recommend doing it? Piece of plywood underneith? ideas!?
Old Mar 21, 2009 | 09:53 PM
pentavolvo's Avatar
liquid nails some plywood underneath then screw into that
Old Mar 22, 2009 | 02:20 AM
vjo90rs8's Avatar
I mounted mine to the carpet using some nuts and bolts. The carpet is pretty thick so the amps have enough padding underneath them and the carpet is so strong I don't have to worry about the nuts ripping out.
Old Mar 27, 2009 | 04:49 PM
slvr20cam's Avatar
I used partical board underneath carpet...works great
Old Mar 27, 2009 | 05:03 PM
samson_420's Avatar
^ That looks real nice and clean.
Old Mar 27, 2009 | 09:47 PM
Silver Rocket's Avatar
put a piece of wood down the side of the area, 1/8 inch will work and then carpet it with matchin or whatever color you would like, then mount it to that
Old Mar 27, 2009 | 09:49 PM
or you could always go with somethin like this
Old Mar 28, 2009 | 04:54 PM
99345hp's Avatar
^^ That would be ok if it fit right. The sides of the amp rack look like a kid cut them out.
i layed a piece of 1/2" plywood down and just layed the carpet on top of it. Screwed the amp down to the wood through the carpet. The carpet keeps the wood and amp from sliding around.
Old Mar 31, 2009 | 10:00 AM
mild2wild's Avatar
slvr20cam - did you buy that insert for your subs or did you fab it? Just wondering where I can find one like that for my single 10" sub...
Thanks
Old Apr 1, 2009 | 12:37 PM
slvr20cam's Avatar
fab'd the whole thing
Old Apr 1, 2009 | 12:44 PM
mild2wild's Avatar
Well it looks great! Guess I better get to work'n on mine
Old Apr 1, 2009 | 02:17 PM
LS1-MEX's Avatar
jl makes a stealth box for the 10inch
Old Apr 1, 2009 | 04:55 PM
vjo90rs8's Avatar
so does keeaudio and subthump for a lot cheaper
Old Apr 1, 2009 | 05:17 PM
b.lee's Avatar
Wink
I just let mine fly around in the back
Easy to take out on track days
Old May 20, 2009 | 07:52 PM
greezy's Avatar
sorry to bring back an old thread but.. how much room do you have between the tub metal and the gas tank. if i was to sink a quarter inch sheet metal screw into the bastard would i..uh..die or anything?
Old May 20, 2009 | 11:10 PM
shoemike's Avatar
I made a bracket out of sheet metal.
The amp bracket is held down by the baby seat anchor bolts.
