Radio Problem (buzzing)
Old 03-23-2009 | 07:39 PM
firebirdman469's Avatar
Question Radio Problem (buzzing)
So I get my car out of storage over the weekend, change all the fluids, and start her up. Then, I hear an annoying buzz coming from my radio. It increases in pitch the higher the RPMs go. I did some trouble shooting, and I have found that the sound goes away when I unplug my RCA cables that go to my amplifier. After brainstorming I think it could possibly be a bad ground. I took the alternator out, had it tested, and it passed. I then checked all of my wiring behind the dash and the ground to the main harness is fine. Then, I bought a ground loop isolator and installed that. When the isolator was installed, the hum went away, but the subwoofers didn't produce any sound... So now I am out of ideas... Any input would be greatly appreciated!!
-James
Old 03-23-2009 | 09:01 PM
95TAJade's Avatar
by chance do you have a pioneer head unit?
Old 03-24-2009 | 04:29 PM
I do, it is an Avic-N2. I heard that there is something internal that could go wrong with it that causes interference....Is that true?
Old 03-24-2009 | 07:57 PM
95TAJade's Avatar
Try taking some extra wire and ground the rca to the radio's chassis. Just the outer part of the RCA though. For some strange reason or another, Pioneer's have a tendency to have weak RCA pre-outs from their decks.
Old 03-25-2009 | 10:57 AM
chrysler kid's Avatar
my alpine had this problem when i first got my car. the connections to the radio were done right, and had been soldered but were causing the buzzing noise. i wrapped the connections together with some electrical tape and that elminitated the buzizng noise that was being produced. (the connections were already wrapped individually with electrical tape, i just wrapped the electrical tape around the lines to keep them all together)
however i have also heard pioneers have problems with the rca outputs
