Which kick harder?
I was a bit skeptical, as the "premium" package came with CDT CL-6 midwoofer drivers, and KEE's website says its base frequency range is ~65 hz
But the DVC Bazooka Sub has a frequency base of ~39 hz and has more power handling capabilities it would seem
Which is louder and has better sound quality in the lower ranges? (I do not care much for my bass drivers kicking above 1000 hz anyway)
I am mostly looking for decent quality, but loudness is what I really want.
Thanks ahead of time!
I am on a budget and the packages are hard deals to turn down, I'm still just worried about the bass output on either package
As for the original question...which hit harder...on the stock system, the Bazookas will hit hardest because they utilize the stock amps power the best being DVC subs. I recommend the premium system for aftermarket systems using aftermarket amplification or if you plan on aftermarket amps in the future so you don't have to swap speakers again. For a stock system though the standard package does fine.
I also want to point out that any of the CDT drivers like the M-6, M-6+, and ES-06 or ES-06+ will not hit hard on a stock system at all because they require aftermarket amplification for optimal results. I would recommend at least 75-100watts RMS power to those and the stock system will not put out anywhere near that. You will be disappointed with them or any speaker like that on stock power.
