WIERD HEADLIGHT PROBLEM "trans am"
Old Apr 13, 2009 | 10:53 AM
blackhawk98's Avatar
Default WIERD HEADLIGHT PROBLEM "trans am"
When I turn my head lights on mt t/a all 4 light come on and there all dim except for the far driver side light any ideas... i changed the switch and still same prob.
Old Apr 14, 2009 | 05:19 PM
tacklebox's Avatar
I have the same kind of problem. When i turn on my low beams, all my lights come on but the drivers side low beam is really dim and both hi beams are about half brightness. And my left blinker arrow illuminates when i turn the lights on. I have no clue.
Old Apr 16, 2009 | 07:16 PM
tacklebox's Avatar
I fixed my problem. It was a loose ground wire on the upper drivers side radiator support. As soon as i tightened it down, everything works perfect.
Old Apr 16, 2009 | 09:18 PM
Cool ima check it out
Old Apr 17, 2009 | 12:46 PM
Racer383's Avatar
Also check the big connector that the high and low beam wires trace back to. My headlights did some weird stuff until I re-tightened that connector by pushing it together a bit more.
Mark
