gauge cluster pinout...
Old May 21, 2009 | 09:06 PM
C Murda's Avatar
Default gauge cluster pinout...
can someone please show me a gauge cluster pinout for 02 camaro? or well 98-02 camaro
Old May 21, 2009 | 09:46 PM
C Murda's Avatar
ok well let me rephrase this...i need a picture of the actual plug/connector to go along with the following that i found thanks to "lt4malibu"
Pin
Wire Color
Circuit No.
Function
A1-A2
Not Used
A3
PNK
39
Ignition 1 Voltage
A4
Not Used
A5
TAN/WHT
33
Brake Warning Indicator Control
A6-A7
Not Used
A8
BRN/WHT
419
MIL Control
A9
Not Used
A10
ORN
640
Battery Positive Voltage
A11
Not Used
A12
LT BLU
14
Left Turn Signal Lamps Supply Voltage
A12
LT BLU/WHT
1414
Left Front Turn Signal Switch Signal
A13
PPL/WHT
237
Instrument Panel Lamp Control
A14-A16
Not Used
A17
LT GRN
11
Headlamp High Beam Supply Voltage
B1
BRN
9
Park Lamp Supply Voltage
B2
Not Used
B3
GRY
728
Security Indicator Control
B4
Not Used
B5
PPL/WHT
1035
Starter Relay Coil Supply Voltage
B6
GRY
1036
IPC Class 2 Serial Data
B7
ORN/BLK
737
Trunk Lamp Control
B8
DK GRN/WHT
817
VSS Signal
B9
GRY
8
Instrument Panel Lamp Supply Voltage - 1
B10
DK BLU
15
Right Turn Signal Lamps Supply Voltage - Europe, Japan
B10
DK BLU/WHT
1415
Right Front Turn Signal Switch Signal - Domestic, Gulf
B11
BLK
650
Ground
B12-B22
Not Used
B14
TAN
31
Oil Pressure Indicator Control
B15
BLK
650
Ground
B16-B17
Not Used
Old May 22, 2009 | 09:53 AM
WhiteBird00's Avatar
Ungrounded Moderator
Old May 22, 2009 | 10:26 PM
C Murda's Avatar
ahh THANK YOU!
Old Jul 5, 2009 | 02:23 AM
brianfromhawaii's Avatar
so i see there is no RPM or anything? But there is a class 2 serial... does that hook up to the ecu's 58 DK GRN 1049 ECM/PCM/VCM Class 2 Serial Data on the blue connector?
Old Jul 5, 2009 | 11:17 AM
shoemike's Avatar
It goes to the Star connector, all modules are joined thru it. (Fbody)
gauge cluster pinout...-186363d1246802509-new-obd-ii-port-question-i-did-search-first-700691.gif
Old Jul 5, 2009 | 12:54 PM
what wire is that labeled on the gauge cluster and what wire is it labeled that comes through the firewall with the two little connectors?
Old Jul 5, 2009 | 02:00 PM
shoemike's Avatar
What do you mean?
The PCM wire (blue 58) is dark green all the way to the slice and the IPC wire is gray.
All the wires are merged at the slice for data transfer at the DLC. (purple)
Old Jul 27, 2009 | 11:48 AM
pillagenburn's Avatar
i am also interested in this:
what gauges does that serial data line carry the signal for? is the signal interpreted at the gauge cluster? or is the BCM involved there somehow? Does the BCM do any actual interpretation of the signal or is that done at the gauge cluster?
Old Jul 27, 2009 | 02:23 PM
The gauge cluster interprets class 2 serial data for the following gauges and indicators:
- ABS Inop indicator
- Airbag indicator
- ASR Off indicator (TCS Off in Firebirds)
- Brake warning (only to indicate loss of serial data signal)
- Change Oil indicator
- Check Gauges indicator
- Coolant Temperature gauge
- Fuel gauge
- Low Oil indicator
- Low Traction indicator
- Skip Shift indicator (M6 only)
- Service Vehicle Soon indicator
- Tachometer
The BCM doesn't receive or interpret any serial data.
Old Jul 27, 2009 | 07:17 PM
anyone know if the e38 PCM can/will successfully communicate with the class 2 serial data instrument panel cluster of the 1999+ f-bodies?
Old Nov 26, 2014 | 11:11 AM
autowolf80's Avatar
- Airbag indicator
- Fuel gauge
- Low Oil indicator
- Tachometer
Based on that response you should be able to run the serial data wire to the cluster pinout straight from the pcm to get the cluster operational? I am trying to find out what all I would need to get a 2000 or so truck cluster working in a 81 c-10 LS swap. I know that fuel guage won't work, but if I wire in the pin outs on the connector from the pcm, lighting, turn signals and maybe Check engine should all work correct?
Old Jan 1, 2015 | 09:01 PM
southernculture's Avatar
Ever figure this out?
