key fob range
Old Jun 8, 2009 | 04:28 PM
tx3's Avatar
tx3
Default key fob range
Question:
I have two key fobs.. Both have almost no range to unlock/lock doors.. I've tried swapping batteries on them.. but have not much effect.. is there anyway to fix this?
Old Jun 8, 2009 | 05:02 PM
98 WS6's Avatar
I have the same problem. I can be standing at the end of my driveway, with my car at the other side of the driveway, and it won't get the signal. I think they just suck.
Old Jun 8, 2009 | 10:21 PM
bad_408_vert's Avatar
Aftermarket Alarm/remote and VATS bypass.
Old Jun 8, 2009 | 11:04 PM
dragonrage's Avatar
Find the antenna in the car and replace it with something better.
Aftermarket works too, but if range is all you want, then I'd say don't bother.
Old Jun 9, 2009 | 01:23 AM
bamalt1's Avatar
My fob has great range unless there's a ton of cars around then its about 5 parking spots away. Mine is model # ab01502t if that helps any.
Old Jun 10, 2009 | 02:10 PM
Danny2tek's Avatar
When Im out of range I always do the old "put the fob under your chin trick".....nobody else?
Old Jun 10, 2009 | 02:36 PM
bamalt1's Avatar
Nah I usually just leave mine in my pocket and just reach in and keep hitting the button till it unlocks.
Old Jun 10, 2009 | 02:51 PM
dragonrage's Avatar
I've tried that a few times. It has never helped me with anything, except looking like an idiot.
Old Jun 12, 2009 | 08:48 PM
Super Speed's Avatar
Try pinching the fob together, that always seems to give mine more range when I need it for some reason...
Old Jun 16, 2009 | 03:28 AM
Scira's Avatar
I've heard that you can solder just a wire to the antenna inside the fob and it gives it better range
Old Jun 16, 2009 | 09:59 AM
VIP1's Avatar
Copy & Paste Moderator
Although that does work for some fobs, I haven't found the right spot in the f-body fob. Maybe Whitebird00 can chime in. Which item in the fob is the antenna? I can't seem to find it. The closest thing I can find is a trace running along the edge of the board, but I'm not sure about that. On some fobs its a small metal box. On some fobs its a thin bare wire. On the f-body fob...?????
