Amp Question
Old Jul 10, 2009 | 10:27 PM
Choppers's Avatar
Default Amp Question
How would this amp work with 2 of these 8' subs that I will provide the link for. Would it be to much not enough? Also anyone ever use power acoustik? I have have never used them before. Ya'lls thought will be helpful.
Amp:
http://www.crutchfield.com/S-g9nwwaS...k-TS960-4.html
Subs I will have 2 of these:
http://cgi.ebay.com/RE-AUDIO-US-AMPS...3A1%7C294%3A50
Old Jul 11, 2009 | 12:20 AM
Engine_HP's Avatar
no they will not work together,
Old Jul 11, 2009 | 07:48 AM
Choppers's Avatar
to much power?
Old Jul 11, 2009 | 11:19 AM
Engine_HP's Avatar
Originally Posted by Choppers
to much power?
no,
this is a 4 channel amp when bridging it to 2 channel it will stable at 4 ohm,
the subs are dvc 4 ohm, when connecting them in parrallel the will produce 2 ohms load,
Old Jul 11, 2009 | 02:48 PM
Choppers's Avatar
ok yea i think i am just going to save up for what i really want anyways.
Old Jul 12, 2009 | 04:31 PM
Snootch's Avatar
You could use that amp with those speakers, but to power more than a pair of subs. You could wire each of those subwoofers voice coils in series so they are essentially 8 ohm subs, then wire both the subs in parallel so they present a 4 ohm load to the amp on channels 3-4 (bridged). Then use channels 1 & 2 to power your front speakers (front doors). Remember, If you will be using the factory deck you will need a line output converter as well as some RCA cables to connect to the signal input to the amp. Also, don't forget to buy a decent 8 gauge power wiring kit for the amp as well. You might want to check out Kee audio (sponsor) to see what they can do for you as well. --->
