Front turning signals Please help and give info
hey guy my name is dale smith, and i have a question about, the front turning signals, on my car, if on of the bulbs, go out would that make both of them go out... i pulled the inside turning signal light, and it looked as if it hade friend, when the bulb blew.. looks like it got too hot, and the heat fried it... give me soem feed back guys thanks...
Not Sure, But
My R/F signal would not flash and when I looked at the connection it appeared darkened as if it got very hot. Anyway, I replaced all the turn signal bulbs since I was already there and it was a pain to access. I also put a small amount of dielectric grease on the bulb receptacle. It solved my problem. I would start with replacing the bulbs since they are a cheap fix and go from there.
