satellite radio antenna help
Old Aug 13, 2009 | 06:20 AM
TROYCO's Avatar
Default satellite radio antenna help
i just installed a satellite radio system in my camaro, and the magnet won't stick to the roof (too much plastic in the car i guess) so i was thinking about using double sided tape to hold it on, but will this harm the paint or anything else in any way??
here's the brand i have:
Old Aug 13, 2009 | 07:48 AM
jam01's Avatar
i installed satelite in my car also, from experience i would use it. with out it, the antenna moves around and leaves scratches. the worst i see that stuff doing is leaving some glue on the panel, which i am sure could be cleaned with a cleaner like goo be gone or something.
Old Aug 13, 2009 | 04:25 PM
TROYCO's Avatar
thanks. i'll do it then.
Old Aug 13, 2009 | 04:27 PM
VIP1's Avatar
Copy & Paste Moderator
My XM antenna is hidden in the hatch itself:
WhiteBird00 hid his antenna under the dash:
Old Aug 14, 2009 | 05:02 PM
TROYCO's Avatar
i like that. do you find any problems with reception??
Old Aug 14, 2009 | 08:29 PM
VIP1's Avatar
No problems. Works great.
Old Aug 14, 2009 | 10:02 PM
TROYCO's Avatar
thanks! i never would've thought of that. it'll look that much cleaner now.
Old Aug 15, 2009 | 04:56 PM
z28pat's Avatar
I mounted mine on the plastic part of the roof behind the ttops with that 3M mounting tape and no problems for over 2 years in all wethers and speeds,
Old Aug 16, 2009 | 10:05 AM
KEE AUDIO's Avatar
The easiest best mounting spot I've found is where Whitebird has his. Reception is good and very easy to do. I have used tha area for antennas on navigation units also.
Old Aug 18, 2009 | 06:48 PM
TROYCO's Avatar
i mounted my antenna under the spoiler, but i'm having problems with reception. how do i remove that part of the dash to put my antenna at the base of the window??
Old Aug 18, 2009 | 08:18 PM
WhiteBird00's Avatar
Ungrounded Moderator
Take off the t-tops. Remove the a pillar trim by removing the two screws at the top of each and then pulling loose from the clips. Carefully pry the dash panel up. It is held in place by a combination of spring clips and velcro strips. Be careful - the edges are sharp and the plastic can become brittle over the years.
Put the antenna on the left side for best reception. This is because overhanging trees and other obstructions will affect the right side more than the left.
Installation is the reverse. Be sure to line up the guide pins on the plastic dash panel with the holes underneath then push down firmly to seat the clips.
