Keyless Entry
Old Aug 23, 2009 | 08:28 PM
frostyallnight's Avatar
Exclamation Keyless Entry
Can I use a 1995 (3rd gen) keyless entry remote with my 2000 Trans Am (4th gen) keyless entry system?
Thank You
Jason
Old Aug 24, 2009 | 07:51 AM
WhiteBird00's Avatar
Ungrounded Moderator
Those are both 4th gen... 3rd gen ended with the 92 model.
The remotes are different but I suspect they both use the same frequencies and codes. I suggest trying it - program the remote and see if it works. If it doesn't then you only have to reprogram for the later model remote. All you lose is a little time.
Old Aug 24, 2009 | 08:38 AM
Thank You for the reply. I will test it out when I get the remote. I order it off of ebay so we will see what happens.
