Door panel removal?
Old Sep 15, 2009 | 11:41 PM
dthompson2634's Avatar
Default Door panel removal?
I want to replace all 4 speakers in my 2000 Firebird with some 6.5 inch alpines next week. I need some help on removing the door panel and back panels. Anyone have any pictures or instructions on how to get them off?
Old Sep 16, 2009 | 12:31 AM
nemss1's Avatar
Remove the 2 screws for the door handle trim remove the door handle trim, remove the 3 screws on the armrest, remove the side mirror trim then slide the door panel upwards
for the sails, just remove the grills which clip in. No need to pull the whole sail panel
Old Sep 16, 2009 | 12:49 AM
bmnicolosi's Avatar
Pictures of what you need to do
Old Sep 16, 2009 | 12:51 AM
bmnicolosi's Avatar
fyi the "6th screw" it talks about is your mirror trim piece screw[black triangle with screw in it looking right at you]
Old Sep 17, 2009 | 01:17 PM
I appreciate it bmnicolosi that helps alot. I'm thinking about just installing the speakers myself. Will I need any aftermarket harnesses or parts? Or will they just screw right into the factory mount?
Old Sep 17, 2009 | 03:20 PM
98 LS1 SC's Avatar
Look at step 5 in the how to that bmnicolosi posted. You may have to cut the back side of the plastic mount the factory speakers fit it if the new speakers have bigger magnets or sit deeper. Other than that they should fit.
Old Sep 17, 2009 | 08:55 PM
bmnicolosi's Avatar
Nope. Just cut the connector off and either butt connect the speaker terminals on or solder them on. As far as above post, if you are going with the speakers we talked about, you will have no depth issue at all.
Old Sep 28, 2009 | 06:15 PM
davered00ss's Avatar
Moderator
Just what I needed to find.
Old Sep 29, 2009 | 09:09 PM
jahmes143's Avatar
I would read up on how the Monsoon system works before you do any installs. Check out the stickys if you haven't already
