Where is this "BCM Ground Wire"
Where is the right one?
Here's the issue I'm having, read post #8 if you have a minute.
https://ls1tech.com/forums/appearanc...-lighting.html
Thanks white bird.
The BCM controls the courtesy lamps using both the power and ground connections. The white ground wire controls the theater dimming effect to turn off the lights after the doors are closed. But the dark blue with white power wire is also used to turn off the lights if a door is left open - this is part of the battery protection function. You can substitute a constant (battery) power source but you run the risk of killing your battery if something goes wrong and the lights stay on all the time (e.g. door switch problem, etc.). The dark blue with white wire is available in all the same locations as the white wire.
Time to go fix this, thanks again man!
