Alternator noise help
If that isn't the case, then I'm fresh out of ideas
I'm not sure why your old one didn't whine but this new one does, unless something is wrong with the new alternator (which I'd kinda doubt, but **** happens). If that isn't the case, then I'm fresh out of ideas
I'm not sure why your old one didn't whine but this new one does, unless something is wrong with the new alternator (which I'd kinda doubt, but **** happens).http://www.crutchfield.com/S-ZdEcytM...ech/kb348.html
I would recommend taking it back out and up to an auto parts store to have it diagnosed on their testing bench. If it still whines there, then it's an internal problem with the alternator. If it works fine, then you have some other electrical problem on the car.
http://cgi.ebay.com/ebaymotors/New-A...4506.m20.l1116
I know its ebay buy his seller rating is outstanding and the Alternator is new and not a reman
I have a 220 amp alt and it used to do that when the engine was cold. Someone told me that it had to something with my Optima Yellow battery and that I should change the positive from the battery to the alternator to a 0 ga. wire, but I never did.
And this was over a year ago, for some reason that high pitch whine just stopped, don't know why.
