LED Wiring Question
Solution 0: 6 x 1 array uses 6 LEDs exactly
+12V__+-_+-_+-_+-_+-_+-__ R = 1 ohms
The wizard says: In solution 0:
each 1 ohm resistor dissipates 0.625 mW
the wizard thinks 1/4W resistors are fine for your application
together, all resistors dissipate 0.625 mW
together, the diodes dissipate 300 mW
total power dissipated by the array is 300.625 mW
the array draws current of 25 mA from the source.
and i have about 200 leds to wire up and so its gonna be all the wires coming off of them to one leading to my headlights
and yes i no from experience because i changed all my interior lights out to blue leds. and its much easier to take idk-roughly a foot of 2 wires or however much you need and then run it close to each led group once they are in place and just keep tying into those two wires (+,-) like that instead of having, like you said, a whole crapload of wires coming out.
