ugh another stereo issue....
Old Nov 4, 2009 | 07:03 PM
N20zuki's Avatar
Default ugh another stereo issue....
Well got the system installed and working correctly... But now when ever the amp is on I get horrible radio reception. I sat out in my driveway and turned on the ign and amp kicks on and reception gets poor. Turn the ign off so the amps off and it goes back to as it is before. Now for wire placement, The remote wire runs down the drivers side to the fuse box, and the 4ga goes along the pass side. The ground wire is connected to a bolt that goes into the bodypanel/fender that can be seen right in front of the spare tire. Am I sharing a ground point with the antenna or is it just to close to it. This is the only issue I have left and will post pics when im done.
Old Nov 4, 2009 | 08:57 PM
bluetransam95lt1's Avatar
I have 2 amps mounted where the spare tire is and I'm grounded to the seat belt mechanism where that bolt goes to the body and haven't had any problems whatsoever. Make sure every ground is clean metal.
