battery relocation?
Old Nov 7, 2009 | 10:53 AM
02b4ccamaro's Avatar
Default battery relocation?
i want to relocate my battery to the trunk, and i dont want to cut up the factory wiring. just want to see any pic or get some ideas on how i can do it.
Old Nov 7, 2009 | 11:09 AM
Ws6kid.'s Avatar
i would like to do the same.!
and out a small fuel cel in where the battery used to be for some N20
Old Nov 7, 2009 | 11:10 AM
blackbyrd's Avatar
several companies make a kit bmr is one of them
Old Nov 7, 2009 | 11:16 AM
Ws6kid.'s Avatar
yea i know they make the bracket to relocate the battery but what about the lines? i would like to see some one make a write up about it or things i should look out for in relocating the battery
Old Nov 7, 2009 | 01:02 PM
squee's Avatar
There is a guy on here who makes a block to do it. All you do is screw the stock cables to the block and run a wire to the back. Couldn't be more simple really...
Old Nov 7, 2009 | 02:21 PM
99Bluz28's Avatar
This should get you going.
https://ls1tech.com/forums/drag-raci...elocation.html
https://ls1tech.com/forums/paint-bod...elocation.html
Old Nov 7, 2009 | 02:28 PM
RAMPANT's Avatar
I just thought I would give you guys an option. I planned the same thing. I bought all the parts seperately since I wanted mine on the drivers side and the bottle on the passengers side. I then weighed all the cable, brackets and mounts. It came to 23lbs, WTF. Add 23lbs to the car so I can move 34? I autocross and take it to the strip so front weight and total weight matter. So I looked into a light weight set up. I went with the 15lb Braille battery. With the bracket it came to 17lbs, for a savings of 17lbs and 17lbs less on the nose. I do have a bigger stereo in the car and it seems to work just fine. Just food for thought.
Sorry, I need better pics of it, but you get the idea.
Old Nov 23, 2009 | 05:13 PM
Y2K WS6's Avatar
so where does a person get the battery and "kit" that's pretty bad assed I like it!
Old Nov 23, 2009 | 06:29 PM
RAMPANT's Avatar
I bought the battery and billet mounting kit from Jegs.
http://www.jegs.com/i/Braille-Auto/147/B2015C/10002/-1
http://www.jegs.com/i/Braille-Auto/1...ALUMK/10002/-1
I made my own lower base to fit the factory tray.
The terminal blocks are from JL Audio XB-PDBU-4 and I used 1/0 guage to feed them the power.
http://mobile.jlaudio.com/products_c....php?cat_id=13
Not a cheap solution but it saved 20lbs and seems to handle my stereo with 155amp truck alternator.
