Head Unit problem
Old Nov 9, 2009 | 08:37 PM
Ws6kid.'s Avatar
Post Head Unit problem
well as the title says well my head unit turns off it the car gets hit slightly. and if its on it turns off for no reason. but turns off right after or takes a few seconds to turn back on.
any suggestions of what it might be?
thanks
Old Nov 9, 2009 | 09:19 PM
XTrackStar06X's Avatar
loose connection with the power supply. check to make sure everything is connected properly
Old Nov 9, 2009 | 09:21 PM
silverz28camaro's Avatar
My girlfriends car does this cometimes as well, do your windows quit working also? Maybe check the fuse make sure its in all the way and the power connector like ^^^^said.
Good luck and post up if ya find the problem
Old Nov 10, 2009 | 03:12 PM
Ws6kid.'s Avatar
ill check that out
anything else that might make this happen?
besides a loose fuse or a loose wire.
Old Nov 10, 2009 | 03:39 PM
Super-Bat's Avatar
If your experiencing similar problems as well, this will be of use to you.
http://www.fbodyonline.com/how-to-fi...dio-and-locks/
It's a problem in your BCM with some solder points.
A similar write up is/was listed in the Commonly Asked Questions Sticky in this section but the noob that did it deleted his post, and pics are missing. The tech article I posted should suffice and be quite useful to you and any other experiencing issues.
Old Nov 10, 2009 | 06:47 PM
Ws6kid.'s Avatar
fixed it i hope
it was a loose ground wire
hopefully it stays working!
