Help Me Piece Out A Stereo For My Car
I coudn't agree more, each to their own alright. If you are looking at kicker, look at their solobaric line.
The new comp line is using the solobaric technology in round speakers from what I read.
I can pick a half a dozen speakers that are great in my opinion. I'm not brand loyal by any means. It all comes down to the tune and how much you want to fork out.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I am no audio guru so i can't say i know performance difference with either route.
I chose a 5 ch amp because it was a cleaner install.
The amp is bolted/screwed onto the side of single 10" sub box. All the wires hidden.
At the track, it just comes out like a laundry bag.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Your going to get alot of differing opinions on what sounds the best. It really depends on what you want to spend and you goals. SQ or SPL? Want to run passive or active? 90% percent of what your new equipment will sound like is tuning and install. Your goals will dictate your equipment. I've been into car audio a long time and have heard many different brands sound good and bad. A properly setup cheap $600 system can sound better than a $2000 improperly setup system.
You don't have to run any back speakers at all. True audiophile systems use just front speakers. Rear speakers are considered for "fill." If you want rear fill, buy one of the less expensive models since you will not be really hearing much out of them. Save your money and buy a good set of front speakers. A good pair are the SPX-17REF, which you can get on ebay for 300. These are audiophile grade. Alpine makes great head units too. Their type R sub is excellent also.
Buy some Dynamat or similar product and deaden your front doors. It will make the sound punchier and louder.
I agree with kee audio that a 5 channel amp makes a lot of sense.
Another thing. There are a lot of amps out there, but this one is something special. ZedAudio Leviathan. Mail order only from a guru in the industry. It is a 6 channel sub, that makes 150w into each channel. You can bridge a pair of channels and make 600W. That would give you 4 channels with 150w, and one sub channel with 550W. $599
Also, it is a Class D, which means it is very power efficient and would not require an extra battery or power capacitor.
He builds amps that last forever. I have a couple from 1999 that still kick ***.
http://www.audiogearreviews.com/revi...-leviathan.asp
Last edited by WhiteBird00; 12-14-2009 at 07:33 AM. Reason: Removed non-sponsor link
it's been said time and time again, 2 components in the front and a sub or two in the trunk. there is absolutely no reason or need to install anything else, especially including rear speakers. i guarantee you with a good quality set of components with an adequate crossover and subs the same quality and corresponding crossover settings, you'll never miss rear speakers or even realize how encompassing the sound will be with only 2 components. also there is no reason to install speakers now and subs later. it might cost more, but the hassle of installing car stereo appliances does not make it worthwhile to do twice because you can't afford to purchase everything simultaneously. either don't do it or wait till you can buy everything and do the install one time and one time only.
#32
Another awesome brand of speakers to look into if you want grade A sound quality along with volume is FoCal. Have a wide range of speakers to choose from whether theyre ur typical coaxials or comp speaker systems. They also have subs and amps and wiring and anything else you may need.
#33
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
the wiring is pretty cheap, and you can just simply leave a little slack for flexibility in final placement, then cut the wires to length once you're finalizing the install. it just takes a little more planning initially, but you should take the time to plan properly anyway.....
