power wire to amp
Old Dec 24, 2009 | 04:37 PM
99ls1fbody's Avatar
Default power wire to amp
were do you guys run the power wire from the battery to the amp for a sub install?? were in the firewall??
Old Dec 24, 2009 | 08:38 PM
98boxer's Avatar
remove pcm and through the fire wall there is a gasket there you can cut in to go through firewall.
Old Dec 25, 2009 | 10:47 PM
WhiteRhino's Avatar
Some disagree, but I ran mine under the car. I drilled a hole and have it come in behind the back seat. Using a grommet of course. Just didn't want that huge cable running through my car. As long as it's secured properly, there won't be any issues.
