Questions About Amp And Sub Install...
monsoon amp powers EVERYTHING
you would just wire to either set of wires if u were bypassing amp it dont matter, cause u will just cut them at the amp and route the signal down them
same with right
http://www.crutchfield.com/p_136J250...-1.html?tp=115
This should sound pretty good paired with my Alpine 10" type R shouldn't it?
All I have to get now is my stealth box.....
If you are running say a 400W, 4 Channel amp, and you have more than 4 speakers, how do you supply power to the other 2 speakers?
Also, When you have component speakers, do you have to run 4 wires to them (both a positive and a negative for the tweeter and mid bass)? If so, where do you get the other seat of power and ground wires if you are running it off the head unit or a 4 channel amp? Thanks
Every amp Ive looked at is 4 channel by 80w @ 4ohm. the 4x100's are at 2 ohms which I cant run my speakers at....
