Questions About Amp And Sub Install...
You will need:
1) A speaker-level converter. (To hook up the stock Monsoon to the amp.) It would probably benefit you best by just getting even a really cheap head unit. It is ALWAYS best to use line-level RCAs vs speaker-level. You will get a cleaner and more powerful sound. BUT you can get by with just a converter.
2) 4 ga. wiring kit. (Power wire, ground, remote turn on, RCAs, speaker wire.) You can go with an 8 ga. kit if you want to save a little money. I would buy come extra speaker wire since you will be running some long pieces to the front. Since you're not building a competition system or anything, I wouldn't worry too much about wire size. 14 ga will be plenty fine for speaker wire to both the sub and speaker.
There is no blue wire coming from the head unit. Just connect the wire to the ignition or ACC.
And DO NOT hook your factory speaker wires to anything except the converter. The only wires going to your speakers will be from the amp powering them.
When you buy a headunit, you take the monsoon out and use either your new headunit to power them or an amp. Either way it will sound much better and eliminate the need for a converter.
Read up:
http://www.crutchfield.com/App/Learn...x?g=120&tp=115
http://signature.crutchfield.com/s_5...6.html?tp=5684
When I install this will It do away with the Monsoon system? Meaning My factory amp will be inoperable? Since It is a 4 channel HU, 1 Channel will go to each door power both the mid bass speaker and the tweeter. Then 1 channel will go to the mid bass speakers in the sail panel, and my rear "subs" will become inoperable correct?
So if this is true..... When I go to install my Alpine Type R coaxial door speakers. I simply wire them in just like the stock speakers. I do not modify the speaker wiring correct?
Any advice or help is greatly appreciated, thanks!
This head unit did away with a flat factory connector with 6 wires coming out of it. What is that for?
Also, How should I wire my new front door speakers? Do I attatch both positives from the stock harness together and then to the one terminal of the speaker and the same with both grounds? Or do I have to cut the wires that run to the speaker and wire everything individually? Thanks!
Also there is a wire coming out of the adapter harness marked dimmer. I am assuming that is for hooking up to your dimmer switch for your dash lights correct? Another wire coming out of the adapter harness is marked: INT IN. What is this for? And there is a remote wire coming out of the Alpine harness. This is the wire you connect to from the amp right?
or run new wire from headunit into the door
or bypass the monsoon amp but just for the front speakers
yes that blue remote wire from the radio is what u wire to ur new amp
