96 WS6 Keyless Entry Issues
Old Jan 5, 2010 | 11:23 PM
97ramsst's Avatar
Default 96 WS6 Keyless Entry Issues
Our 96 WS6's keykess entry doesnt work for some reason. The fob will blow the horn for panic but will not lock or ulock the doors. I have tried reprogramming and it didnt didn't help. Does anybody have any idea what to do to fix it?
Old Jan 8, 2010 | 10:30 PM
transam5.7lt1's Avatar
I had a 1994 trans am that did the same thing, ended being moisture on the control box for the keyless entry, its located on the passenger side kick panel, mine had some corrosion on the connections. I remember unplugging it and taking it off, cleaned it with some fast drying cleaner, left it to dry and it never failed again. I would advise applying some dielectric grease on the connections.
Old Jan 26, 2010 | 06:01 PM
6']['9's Avatar
can you post a pic of where thats located, im having the same problem.. i just dont know which harness it is
Old Jan 27, 2010 | 09:20 AM
DAVE00's Avatar
Not sure 100%, but I think the keyless module on a 96 is located or wired differently then the 95 and below.
Old Jan 27, 2010 | 01:03 PM
WhiteBird00's Avatar
Ungrounded Moderator
You're right... 93-95 models had a separate keyless entry module mounted behind the right kick panel. 96 and newer models had the keyless entry functions incorporated into the BCM (Body Control Module) mounted to the ductwork behind the glovebox.
Old Jan 27, 2010 | 01:17 PM
6']['9's Avatar
so how can i fix it
Old Jan 27, 2010 | 02:50 PM
97ramsst's Avatar
So are 96-02 BCMs interchangable?
Old Jan 27, 2010 | 02:59 PM
DAVE00's Avatar
Once again, not 100% sure but I am pretty sure the BCM on the 96 and later cars also controls the VATs and they are not interchangeable with out reprogram from GM.
