Radio ACCY fuse what is it hooked up to? (power draw issue)
Okay so I have been chasing around a short in my 99 T/A. This thing won't even last over night. I can run the car however long but when I park it for the night it would be dead by morning or midday depending on when I cut it off or started it up. So now if I unplug the radio accy fuse it will stay for as long as up to 4 days (the longest I didn't drive the car so far). I was wondering what all is this fuse hooked up to so I can finish chasing this short or I should say power draw and get it taken care of.
i had the same problem turns out my alternator was messed up it was making this humming noise when everthing was off so i unplugged the battery cable hooked up to the back of it and my battery didnt die anymore so i replaced it
the bcm is on the courtesy fuse, that diagram just shows it, i would hunt down the amp and unplug it by the rear spare and see if the draw goes away
or if that doesnt do it its the radio, its the only two really likely
