VATS bypass switch
Old Jan 15, 2010 | 11:06 PM
Chrisd000111's Avatar
Default VATS bypass switch
so i found a VATS bypass switch for the c4 corvettes, does anyone know if this bypass module will work with a 94 trans am. or has anyone found anything similiar that is meant for f bodys
thanks
oh and heres the link
http://www.mamotorworks.com/corvette?frame=1.862
Old Jan 16, 2010 | 03:06 PM
Spartan7's Avatar
I'm guessing you want something like that so you can disable VATS when you want to drive, but arm it when you park your car.
If that's the case, you can easily build your own for much cheaper. All you would need is the correct resistor and a toggle switch. But then it's just acting like a starter kill. So why not just do a starter kill?
Old Jan 16, 2010 | 05:31 PM
a starter kill wont help me much cause the reason im looking for something like this is cause my VATS is starting to act up and throws the security light every once in a while. i was just looking at this cause its plug and play i would attempt to make my own bypass but ive never messed with resistors or circuit boards ( or whatever you use to make one )
