Amp Rack Pics
Old Jan 31, 2010 | 08:29 AM
bbal4now's Avatar
Here is my current setup. Car is in the garage for winter at the moment so lighting is not great but you can get the idea. Also, some endcaps are missing while I am rewiring a portion of the system. The amps are as follows KX600.1 x2 (running 3 10"L7's) KX550.2 (running diamond d971 component set) and a 350.2 (running kicker ss65.2 component set).
Old Jan 31, 2010 | 10:21 AM
fast01z28's Avatar
hey bbal4now, thats a very clean setup (assuming that the wires will be hidden once you are done with rewiring). are the box and mount painted or are they made of black arcylic?
Old Jan 31, 2010 | 10:43 AM
cfallsguy's Avatar
^^ seems to be too much going on with that setup. Not a fan of all the amps cluttered standing up
Old Jan 31, 2010 | 10:55 AM
bbal4now's Avatar
The box is fiberglass filling the entire well with an MDF top that is covered with bondo and painted. The rack portion is a wood frame with fiberglass top leaving a hollow area where the wires are run. The amps are mounted to 3" fence post metal that is also painted black.
As for the wiring, it runs down through the fence post into the hollow area.
As CFALLSGUY mentioned it is a bit much in the back. If I had planned a bit better I would have condensed to only three amps.
Old Jan 31, 2010 | 08:47 PM
Chrisd000111's Avatar
heres mine
still not all the way done on the inside but gives you an idea. def still alot of room to fit another amp if you wanted two
one with the leds
