Amp Rack Pics
Old Jan 26, 2010 | 08:48 PM
YellowTA1's Avatar
Default Amp Rack Pics
As the title says, let's see some amp racks. Mainly looking for those that are directly behind the back seat. plexiglas? neons? custom lettering on the top? Trying to get some ideas here, as mine is just sitting currently....
all courtesy of Ian at Kee Audio, minus the box....all components swapped to CDTs, and a new HU.
Old Jan 26, 2010 | 08:58 PM
cfallsguy's Avatar
There's a few good ideas in this thread:
https://ls1tech.com/forums/stereo-el...annel-amp.html
Old Jan 26, 2010 | 09:22 PM
YellowTA1's Avatar
thanks, that helped somewhat...but i'm going to get another mono amp to run the subs to mount up there with that one as well. not really sure i'll have the room to put 2 big amps in that space. thinking of going with the jbl 14001, with some sort of plexiglas design, and tubes running through it in the cool white to match the led interior lighting.
Old Jan 26, 2010 | 10:18 PM
cfallsguy's Avatar
On the 2nd page the guy had 2 amps in the one rack, but you could also make two levels of the amp rack if that makes sense. Like build a regular rack then box it off and put an amp stacked on top of the other. Make sense?
Or something like this: http://www.alpine.com.au/images/pdx/pdx_stack.jpg
Old Jan 26, 2010 | 10:37 PM
thecobrahunter's Avatar
Mine:
Old Jan 27, 2010 | 09:17 AM
DAVE00's Avatar
Originally Posted by thecobrahunter
Mine:
Pics don't work, try again.
Old Jan 27, 2010 | 06:24 PM
Shockwave179's Avatar
^ They work just fine...
That's a nice setup cobrahunter.
Old Jan 27, 2010 | 10:05 PM
cfallsguy's Avatar
Cobrahunter, what all are you running with the 3 amps and whats the rating on the amps? And why a capacitor?
Old Jan 28, 2010 | 06:55 AM
DAVE00's Avatar
LOL - Now they do
Old Jan 28, 2010 | 08:03 AM
YellowTA1's Avatar
I'd bet he's running 2 amps for the 2 subs, and the other for his mids/highs. that's the setup I was looking for pretty much...
Old Jan 28, 2010 | 03:54 PM
cfallsguy's Avatar
Thats what I was assuming but I don't see why not run just one amp for both subs, unless he's got some major power to them that I can't see.
Old Jan 28, 2010 | 04:08 PM
The left amp is a 2 Ohm 420W amp for the L 10" sub
The center amp is a 4 Ohm 280W amp for the 4 speakers up front
The right amp is a 4 Ohm 170W amp for the hatch speakers
plus I have another 2 Ohm 420W amp for the R 10' sub where the spare tire used to be
The capacitor is just for good measure for bass response
Old Jan 28, 2010 | 05:39 PM
gulfstreamcpt's Avatar
Guess I can throw mine in here........
Here's the front of the amp rack where we did slots for the T-tops to slide into:
Couple of shots with the neon:
Old Jan 28, 2010 | 08:58 PM
cfallsguy's Avatar
Thats a lotta amps! Why didn't you just get two, one for the subs and for the mids/highs up front/sails and leave the hatch stock? And honestly, that cap probably hurts more then helps but you may not be drawing enough for it to really factor into the setup. Still clean nonetheless.
Old Jan 28, 2010 | 09:34 PM
Yeah, well. That's the thing. I know I wanted to mount some amps there, but didn't wanna go all crazy; wanted to make it custom, but nice. And yes, the capacitor probably only helps a little, but even if it only helps some...that's some that it helps over stock. Lemme tell ya, when people hear those subs hit, and then they see they're just a couple of 10"s, they're visibly impressed.
Old Jan 28, 2010 | 11:04 PM
cfallsguy's Avatar
What 10's are you running? Decent 10's can sound good, then from there up (12's, 15's, etc..) it just gets louder, especially in hatches. I had two 10's in a previous setup and you could hear them and people were impressed but that wasn't enough and now I am hooked on getting more and being louder (and now most people can't handle it, and i have to turn it down and its just CVR's). When I get my next set of speakers bought it'll be my third different setup in 7 months and hopefully that'll be it for awhile, then I'll be making a rack hopefully as clean as yours.
Anyway, not bashing on your setup at all, very clean, just wasn't sure why you went the route you did but to each their own and it works.
And what do you do with your ttops when they're off (if yours has them)?
Old Jan 28, 2010 | 11:12 PM
streetassasin's Avatar
My old third gen, just velcroed on
Old Jan 29, 2010 | 12:55 AM
Running MTX subs. Don't hit like 12"s or anything, but then again, I don't mind not being heard from a mile away. My focus was making sure the sound in the car was clean and strong; but, again, they can hit hard. As for the t-tops, they fit nice and snug locked up in their slots. The reason I didn't go with a sub enclosure for the trunk area is that it's my DD, and I use that back area a lot.
Old Jan 29, 2010 | 09:31 AM
cfallsguy's Avatar
Oh yeah, i was looking at a different ttop box and forgot you had the two stealths. Yeah I have to figure out something with ttops this summer.
Old Jan 30, 2010 | 10:36 AM
nightmarechevy's Avatar
