Alpine head unit
Old Feb 10, 2010 | 03:15 PM
Proofz's Avatar
Default Alpine head unit
I'm looking for an Alpine HU with direct Ipod connectivity. I found the Alpine CDE-102 and the Alpine CDE-103bt... What is the difference between these two units since their price is about $80 different? Also if someone has one of these I'd like some feedback on it if you wouldn't mind!
Old Feb 10, 2010 | 03:17 PM
Proofz's Avatar
Err, I forgot to mention that I think the only difference between the two is the Bluetooth capabilities of the 103bt... not 100% sure
Old Feb 10, 2010 | 06:55 PM
ArkBird96's Avatar
if you don't mind not having a CD player, the Alpine IDA-X305 is a great choice!
Old Feb 12, 2010 | 11:22 AM
DAVE00's Avatar
I read up on that unit and it looks real nice, however one of the biggest complaints from people is it doesn't have a "Mute" button or feature. Thought this was pretty odd and sucks not having that ability. Anybody on here have experience with the 305 in their cars?
Old Feb 12, 2010 | 11:34 AM
RsSean's Avatar
My CDA 8356 has a ipod connector already in the back of it. You just have to run the wire fromt behind the unit to where your I pod will be
Old Feb 12, 2010 | 12:05 PM
ArkBird96's Avatar
Well, yes and no. They don't have a "mute" button on the front panel, but if you hook up your steering wheel controls with the PAC SWI-JACK and set it up, you WILL have your mute feature. At least that's how it works on my IDA-X100. Also, if you want bluetooth and have the KCE-400BT module, it will also mute the audio when you get a call. Make sense?
Old Feb 12, 2010 | 12:27 PM
DAVE00's Avatar
Weird that they don't have that feature on the H/U but it is available with a control adaptor? Is it on the remotes?
Old Feb 12, 2010 | 03:48 PM
ArkBird96's Avatar
I would assume that it does, but I don't have the remote, so I can't say for sure. There is also a mute lead that comes out of the wiring harness on the back that you can connect to your cell phone (not sure how), but you might be able to wire a switch to that or something. Plus if you are playing your iPod on it, you can always hit pause. I do that a lot.
Be advised though, that the mute function on the Alpine is not a true "mute." It drops the audio level down quite a bit (enough to get the job done), but it doesn't completely drop out the audio.
Old Feb 12, 2010 | 04:04 PM
tremiles's Avatar
I've got the old IDA-x001, the grand-daddy of the 305, and I'm very happy with it. The "mute" reduces the sound output, but doesn't completely mute it. I use the play/pause button to "mute", although this doesn't work for the radio which I almost never use anyway.
