Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird How to Install Steering Wheel with Radio Contorls<br>Step by step instructions for do-it-yourself repairs.
00+ Steering Wheel with Controls into an older Camaro install.
My z28 is a 98 but it had the monsoon system I believe because it has sail speakers and speakers in the rear hatch. Does this mean my car has the SIR with the plug for the radio controls?
Sorry to bring this back from the dead but I have a question... I am installing steering wheel controls on my 99 z28 which does *not* include the car-side of the harness. I already did everything necessary for the column side of the wiring and SIR Coil. I ordered a Steering Wheel Radio Control Harness on eBay:
https://www.ebay.com/itm/37097427905...oAAOxyVaBSwIny
But, I notice it has 2 small connectors on the ends of it as well. Where do those get connected?
![](https://i.ibb.co/Z2G7wXS/FBSWRB-08999-1477572592.jpg)
There are indentations in the steering wheel to tuck the wiring into like so:
![](https://i.ibb.co/S0vLWq4/s-l1600.jpg)
Yikes... I may have ordered the incorrect part. I'm looking for the wiring that goes from the column into the body harness or stereo harness. Mine only has the Airbag wiring for the SIR coil.
Yes, for the three wires that are already in the factory harness (illumination, power, ground) I just tapped the existing radio harness. For the last wire, the radio control wire, I snagged an extra pin from another connector, wired it, and inserted it into my factory harness to work with the radio.
#32
I'm in the middle of swapping mine and ran into trouble trying to center the clock spring. They said on the other forum that you press the service spring and turn the wheel the way the arrow shows until it maxes out and then back off 2.5 turns. I went lock to lock with mine and got 6.5 turns so I'm scared of doing the 2.5 thing because I don't want to break a hard to find clock spring if the 2.5 isn't actually half way.
#33
If yours is showing 6.5 turns lock to lock then you should be good at centering it at 3.25 turns I would think. When I did mine I marked it with a paint pen and then used some painters tape to keep it from moving when I pulled it out so I didn't accidentally mess anything up.
#34
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/1431x1908/ab109671_ad8d_45d9_a08c_11ce3c5bc814_640ee8da15ab7f3c828c1db39b2b4bbb5fa51861.jpeg)
This is my factory radio harness. You’re saying you connected a pin to your power wire for the wheel controls and put it in the spot right between the yellow and beige?
#35
#36
Edited pic just in case anyone else sees and is curious. Pin 14 is in the connector below the lime green wire:
![](https://i.ibb.co/5cJBxL0/ab109671-ad8d-45d9-a08c-11ce3c5bc814-640ee8da15ab7f3c828c1db39b2b4bbb5fa51861.jpg)
Yes, if you were wanting to keep the factory head unit then you would plug it into that pin 14 spot in the factory connector. For the Metra Axxess Interface you purchased, you could connect the yellow/green pin 3 on that module to the radio control wire and you'll be good to go.
The following users liked this post:
Josh higbee (02-16-2023)
#37
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/71c2fc1a_3187_4954_835c_169a718b700c_dc5d7e8959d93a652ed3736e197470b55236a8ed.jpeg)
Heres what I have. I verified yellow and gray w black stripe both have power on both ends (at the radio harness tap point, and at the connector for the column. Ground I tested using the 200k ohm setting and got a reading of 01.2 on both ends. I can’t get the lights to come on for the wheel controls
also on my head unit I have the “steering wheel control” line on the new head unit harness wired straight to the adapter (yellow and green pin 3) for the wheel controls. I then tried tapping the blue wire on the female plug in to that connection but get no power from that one. What am I doing wrong??
so my two questions are:
1 why won’t the controls illuminate even though they show power? Possible bulbs are out?
2 how do I properly wire up the blue wire to the steering wheel control wire out of the head unit and to the metra adapter? Because I used the #3 pin straight to the harness off the hu labeled wheel controls and then tapped the blue wire into it because idk where else it would go, but either way the metra adapter won’t light up.
