COMPLETED 8's in sail panels
Old Jun 30, 2010 | 10:42 PM
530Racer's Avatar
What all would be required besides making enough room? I could use the stock harness and amp correct?
Old Jun 30, 2010 | 10:46 PM
Breathing Fire's Avatar
Ya you can use the stock amp. The only thing is the original 6.5 subs are 2 voice coils. That part would be the only hard part. What I did was actually cut some plates of sheet metal and welded them inside on my car. I still had to cut the original 6.5 opening to fit the 8" and I gained about a half inch clearance over what the OP of this thread did.
Old Jun 30, 2010 | 10:55 PM
530Racer's Avatar
Im not worried about makeing it fit. Just the electric side of it
Old Jun 30, 2010 | 11:03 PM
Ya that is the hardest part. Mine are amped and I don't remember how exactly I wired them. I don't remember if I used the sub outs on the deck or just used the monsoon amp signal to my amp. Been a while since I did it but I do know the amp will accept preamp signals. Probably just did it the most backaswards WTF way possible. Usually how my wiring ends up.
Old Jun 30, 2010 | 11:14 PM
530Racer's Avatar
hahaha ok thanks for the help man
Old Jul 1, 2010 | 12:01 AM
530Racer's Avatar
How does this sub look?
http://www.crutchfield.com/p_20610C8...b&ssi=0&tp=111
Old Jan 11, 2025 | 02:57 PM
SLPHawk300's Avatar
I’m well aware this is an ancient thread - but if you still happen to be here - I was wondering how you attached the speaker to the sail panel? I see you drilled new holes, did you use sheet metal screws or did you rivet them in?
Old Jan 12, 2025 | 08:11 AM
Finkledbody's Avatar
Try looking into:
Rivet nuts
Snap in nuts
Press in nuts
Clip-on nuts
Adhesive-mount nuts
or weld in if u got it.
anything of these are better then just screwing it into the sheet metal.
Old Mar 12, 2025 | 09:07 PM
SLPHawk300's Avatar
Originally Posted by Finkledbody
Try looking into:
Rivet nuts
Snap in nuts
Press in nuts
Clip-on nuts
Adhesive-mount nuts
appreciated, thank you. I used rivnuts and they worked great!
