Trans AM Headlight harness connector?
Old Feb 23, 2010 | 02:16 AM
TransAmusaf's Avatar
Unhappy Trans AM Headlight harness connector?
I was hoping I could get some help.the harness connector for my right side headlight/lights is corroded and no good. I was wondering if anyone has a spare or knows where i could gt just the connector. I can solder well so installations not problem. the only thing I've been able to find is the headlight motor with the connector for 160 which means I still have to pay for the other side. 300 for a corroded connector would really **** me off.
Old Feb 23, 2010 | 02:57 AM
TireSm0ke's Avatar
are you just looking for the 2 pronged connector? Or the entire 6 prong harness connector? You can pick up the 2 prong connector from autozone for under 5 bucks, I cant recall the part number but just find the headlight or bring in an old one and try some of their 2 prong headlight connectors, I believe its blue. Ill try to find a PN for ya, let me know if you cant find it.
Old Feb 23, 2010 | 08:36 AM
I need the 5 prong, the one the headlights and motor connector to.
Old Feb 23, 2010 | 12:28 PM
WhiteBird00's Avatar
Ungrounded Moderator
If you mean the 5-pin connector that plugs into the headlight control module, it is GM part number 12102775.
Old Feb 26, 2010 | 03:57 PM
Danny2tek's Avatar
You can use some spade connectors like I did.
Old Nov 22, 2014 | 12:10 PM
Josh Camp's Avatar
I run into this issue.. 5 pin connector is coroded.. How do you release the pins?.. Or should I just get cut it and use butt connectors w heat shrink?
2 left ones are for the motor
Old Nov 22, 2014 | 12:15 PM
Josh Camp's Avatar
Ok nvm.. Got em out w a staple.. But where do I get a new terminal lol
Old Nov 23, 2014 | 10:46 PM
BubaGumpShrimp's Avatar
google this part number 12102775
