Monsoon Speakers Upgrade
Maybe ive got the polarity wrong somewhere on one of the speakers, who knows. It definitly is not what I was expecting. Mach 460 in the mustangs sounds twice as good.
Btw, Ive still got the stock HU and amp. Perhaps Ian can help me out on this....?
Also, you may be expecting too much from that speaker kit. With an aftermarket head unit and those speakers, your system will sound clearer and quite a bit better than stock. The bass will be crisper and slightly more powerful but it's no substitute for a separate sub and amp. "Hit" is not a word I would use for the effect of a couple of replacement 6.5" subs.
Btw, I noticed later after posting this that the passenger side sub does not play at all. Not with any speaker, so it has to be wiring, amp or hu on that part.
You did wire the two voice coils on the subs in parallel to the single pair of wires in the sail panels on your Camaro? If you only used one pair of terminals on the speakers then you're giving up half your power there.
Also, is there anyone who can refurbish the stock hu. I dont exactly want to put an aftermarket stereo in because i like the looks of all original plus having the steering wheel controls.
So long story short: To the OP, go ahead and get the kee audio kit. But dont expect anything more than very subtle improvement over the stock speakers, unless of course your current ones are blown or something.
I will be bypassing the amp entirely since its junk anyway, and installing a new HU even tho I wanted to stay away from that. At least with these new speakers, it sounds good enough to get me by until I get a new HU and should sound alot better running off an aftermarket HU.
