Power Mirror Conversion
Old Feb 28, 2010 | 08:03 PM
battousai's Avatar
Default Power Mirror Conversion
Hi, I have manual mirrors on my camaro, and I recently broke my mirror trying to fix it. I was wondering how hard it would be to convert it into a power mirror setup for both mirrors.
I know I would need the power mirror assembly for both sides, and the switch. Would I need anything else other than the fuse and wires?
Old Mar 1, 2010 | 09:04 AM
wssix99's Avatar
Save the manuals!
I'd expect that your wiring would already be in the car. Do you have a spare socket at the switch in the door and at each of the mirrors? (The spare at the mirrors could be tucked behind the door panel.)
Old Mar 25, 2010 | 08:57 PM
battousai's Avatar
I know it took a while, but I finally was able to take my door panel off, and there was no extra plugs or wires inside of my door. I am having a hard time finding a replacement mirror under $50.
Old Mar 26, 2010 | 08:03 AM
wssix99's Avatar
Save the manuals!
Do you have power windows or locks? If so, do you have another socket where those switches are in the door?
$50 sounds like a good price to me. If you are looking at doing the whole job for under $150 for both sides, you should probably abandon your quest.
Old Mar 26, 2010 | 04:03 PM
rukus1_one's Avatar
you need the cross body harness!!!!!!!!! trust me i did it
Old Mar 27, 2010 | 11:02 AM
battousai's Avatar
power locks
no
the whole body harness with every connector? wow, that seems like way to much work
Old Mar 27, 2010 | 12:47 PM
wssix99's Avatar
Save the manuals!
Yea, it sounds like you'll need a different harness or will need to run your own wires. Unless you are changing your mirror positions a lot, it may not be worth it.
Old Mar 27, 2010 | 04:33 PM
battousai's Avatar
Okay, I guess I will just get the manual mirror.
