BCM problems...
Old Mar 2, 2010 | 03:39 PM
EW WS6's Avatar
Default BCM problems...
I think that my BCM in my 98 trans am went bad. Anyone know if a 98-02 V6 BCM is different from a 98-02 V8 BCM?
Old Mar 3, 2010 | 07:44 AM
WhiteBird00's Avatar
Ungrounded Moderator
Originally, there were two different BCM part numbers - one with the optional alarm system and one without. They have been superseded to a single part number (with alarm) for all 98-02 F-bodies.
Other questions come to mind. Why do you think you need to replace your BCM? What is going wrong with the current one?
You can't reprogram a used BCM to match your ignition key so you will have to do a VATS bypass if you install a used BCM.
