need speaker help
Old Jan 3, 2004 | 02:11 AM
tuffluck's Avatar
Default need speaker help
i have an '00 Z28, with the 500 watt monsoon 6-speaker system. my front 2 speakers blew.
my friend has an '02 Trans Am with the 500 watt monsoon 10-speaker system (he has upgraded).
so my friend gave me his front 2 speakers, and the two tweeters that go up there also.
how the hell do i convert the system where i can plug in his front speakers/tweeters combo into my front speaker connection and still get the same sound i had before? is that possible? is that recommended, or is it too much work? thanks for your help...
Old Jan 3, 2004 | 12:00 PM
tuffluck's Avatar
the adaptor that you plug the camaro speaker into (the adaptor/connector coming out of the car door) is the same adaptor you can plug the midbass of the TA speaker in - that is JUST the midbass, not the extra tweeter. the extra TA tweeter has a separate, different connector that doesn't exist within the camaro. obviously, the camaro speaker has the tweet built into it, whereas in the TA speaker, the tweet is a separate unit. so can you hook up JUST the midbass (since the connector only will allow just that). or do you have to do some really funny wiring in order to get the tweeter wired in also? would it sound fine if i just put the midbass in, and not the tweeter? would it blow the midbass or the amp? i don't know where the hell i would mount the tweeter anyway, and it seems simpler just leaving the tweet out... let me know, thanks!
Old Jan 3, 2004 | 04:55 PM
tuffluck's Avatar
bueller?
