Kee Audio standard package and big3
Old Mar 30, 2010 | 06:44 PM
Empatho's Avatar
That's most likely what I read
Old Mar 30, 2010 | 08:56 PM
N34Stryker's Avatar
not to thread jack, but I just got the replacement package from kee as well. How in the hell do you replace the rear hatch speakers? i feel like I am gonna break the mounts
Old Mar 30, 2010 | 09:19 PM
Red97LT1's Avatar
I had to take wire cutters to cut the rivet from them and then they rotated to either the left or right(don't remember) and then they came out.
Old Mar 30, 2010 | 10:34 PM
Empatho's Avatar
+1 on the wire cutters.
any tips on tuning/setting up the amp?(pic of the controls). Is the input level the gain?
Old Mar 31, 2010 | 01:40 AM
Empatho's Avatar
The amp has a "Remote Subwoofer Level Control", is that like a bass boost? I know bass boost is not good, so is it better to not even use this?
I have settings set at this
bass boost - 0db
subsonic filter - 35Hz (ported box)
low pass - 95Hz
Speaker Specs
10" subwoofer with selectable 2- or 4-ohm impedance (have it set at 2-ohm)
frequency response: 25-400 Hz
power range: 50-350 watts RMS (1,400 watts peak power)
sensitivity: 89 dB
Old Mar 31, 2010 | 03:33 PM
Red97LT1's Avatar
I use this info when setting up my amps.....
http://mobile.jlaudio.com/support_pages.php?page_id=143
http://www.ronelmm.com/tones/
BTW,where's the ground on the engine block?
Old Mar 31, 2010 | 10:52 PM
Empatho's Avatar
Thanks man, that is going to come in handy. For engine ground I used the alternator bracket.
