Why are my turn signals just staying on ?
Edit: He is right if both sides stopped working at the same time it is most likely your flasher. Either that or you have a bulb blown on both sides.
this question may be related:
when i flip on the blinkers or hazards, the lights do not flash or come on at all, but they will turn on when i switch on my parking/driving lights. Even then, though, they will not flash when the blinkers or hazards are on. Is it some sort of two way bulb that needs replaced or does the flasher unit need replaced?
Ungrounded Moderator
That doesn't necessarily mean that the bulbs are burned out although that is quite common. Our cars also have poorly designed front housings that allow water to collect at the socket and cause corrosion. Corrosion in the socket will prevent even a good bulb from lighting. So pick up a couple of replacement bulbs (they're fairly cheap) but also check and clean the sockets when you change the bulbs.
