Powering Amps
Old Apr 6, 2010 | 08:18 PM
Bobs-00-SS's Avatar
Default Powering Amps
I am gonna be running a 1000w mono amp for two subs and a 240w amp for the speakers. Will 4ga be sufficient? If so, What is the best way to distribute power to both? Do they make a distribution block? Thanks
Old Apr 6, 2010 | 09:13 PM
pentavolvo's Avatar
Rms???
Old Apr 6, 2010 | 10:26 PM
cfallsguy's Avatar
Yes 4 gauge would be sufficient and yes you can purchase a distribution block for both amps.
Old Apr 6, 2010 | 10:36 PM
squee's Avatar
I'd go with 0 gauge and run the biggest your amps can handle. The input on my 4 channel can only take 8 gauge, and my 2 channel will take 4 gauge so I went with the KnuKonceptz fused digital distribution block which will accept up to 2 0 gauge inputs, which I used both, and then used the 4 gauge for my 2 channel and the 8 for my 4 channel. Its gonna take the path of least resistance, so you really can't go too big (within reason of course).
Old Apr 7, 2010 | 05:27 PM
99Bluz28's Avatar
Is that 1240 rms watts, or peak?
There's a big difference between the two!
Old Apr 7, 2010 | 08:01 PM
Bobs-00-SS's Avatar
It is RMS
Old Apr 7, 2010 | 08:40 PM
pentavolvo's Avatar
4ga will work but IMO 0ga is what u should run with
Old Apr 7, 2010 | 11:53 PM
99Bluz28's Avatar
Thumbs up
2 gauge(if you can find it), or better yet 1/0 gauge.
