not really happy with audio pipes
Just my .02
It sounds like you might have the wires connected incorrectly. The Camaro Monsoon amp is designed to power a 2-ohm sub in each sail panel. The Audiopipes are dual voice coil 4-ohm speakers. You have to connect both positive terminals and both negative terminals together on each speaker to produce the expected 2-ohm load for the amp.
Bear in mind that the result should be better than the stock speakers but there is no way it will compare to a larger sub with separate amp. And there is a reason that the Bazookas are less expensive - you get what you pay for. Properly connected, the Audiopipes are better than the Bazookas despite their popularity.
I saw something on here about running the speakers in a parallel and that's what I did. Meaning I ran the positive and negative to one side, then soldered in two cables that go across and connect to the other + and - on the other side.
With the Bazookas I've never had one come back due to manufacturer defect. They have been absolutely bullet proof since day one. They also can handle more power...about double the output of the Audiopipes. Not a huge deal as far as stock output goes but they do put up with more abuse without issue.
As far as price difference...the Audiopipes cost me less so they are less. The Bazookas cost me almost double what the Audiopipes do....but as you can see I do not charge double for them. I try to keep the prices as reasonable as I can.
